mopardwh
- 219
- 4
- Mar 19, 2005
Evansville,
Indiana
So I lost all the pressure in my clutch. Found the leak between the clutch fluid chamber and the slave cylinder, so I replaced the line. Started bleeding and couldn't even drain the resevoir twice. Even used vacuum from the car at high idle. So I removed the entire master cylinder and pushed in on the plunger with my thumb over the outlet. It just pushed back through the top. So I disassembled it and sure enough found bad seals.
Well after pricing a new one at a few places, I decided to just rebuild it. Now I've tried 9 different part stores and can't find a kit. Everyone has a part number, but can't even get one.
So has anyone ever been through this? Did they just quit making this kit?
Forgot to mention, the dealer has the rebuild kit but its 50 bucks for a couple of seals and springs!!! I can get a reman for 70.
