Clutch master cylinder question
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
Ok, so I just installed a new clutch master cylinder, along with the SS clutch line to replace the accumulator and rubber hose, after bleeding the clutch, my clutch is much softer to push than it did with the accumulator and rubber hose. Is this normal, or did I not bleed it enough or? Engagement is fine, drove it around with no issues too.
It's probably a combination of a good master cylinder finally, the ss clutch line, and no accumulator. If everything works good I wouldn't worry about it.
