adidasdudegst
- 40
- 0
- Sep 4, 2010
Plymouth,
Minnesota
Ok, so I went and picked up yet another Clutch master cylinder. This time from napa rather then ebay. It's still got the big ass ball type mount on it, that makes it look like its for a totally different car, i drilled the old one that looked like that out to make the pin for the pedal assembly fit, because otherwise it wouldnt work. And it wont even let the pedal make it to the floor before the rod bottoms out in the master cylinder. So i then use the oem bracket with this napa master cylinder and it's not engaging/disengaging the right way, even with proper adjustment and proper bleeding. I'm guessing that is because the master adj. rod/piston is moving to far one way or another because its designed to work with the bigger mount and it's opening the bleeder to much?
Anyone know how to make the big mount work correctly?
