Ozyeclipse
- 88
- 0
- May 26, 2012
Gadsden,
Alabama
Ok so I know there's plenty of clutch threads out there but I have an issue I just can't seem to figure out every time I search and view threads its always the same bleed adjust and search
But no actual thread about fixing this yet
I've got a 99 gst stock 7 bolt 147xxx miles new clutch at 122xxx miles
No ticks no weird noises no driving issues besides the clutch engagement feels very close to the floor I've read a lot of crank walk threads and plenty of searching but nothing answered about this
The symptom is that when pressing the clutch it feels fine but 3/4 of the way it just gets hard...
Very stiff and at this point is where I can shift smoothly and normally anything before that and its a struggle to get it into gear
Same goes for relising the clutch about 3/4 of the way(still pressed 3/4) it just feels like it jumps out and disengages right there and would instantly stall or jump
New master cylinder in and bleeding the clutch almost for 3 strait days now also bleeding the slave
And it seems to be getting better but still the same as described above
Could this be an issue from crankwalk it feels like the engagement point is so low to the ground maybe the trust bearing could be wearing out this a a bone stock 7 bolt btw
Could it be a bad tob a broken clutch fork or a bad pressure plate the car has been like that ever since I bought it so I don't know what could have had caused it
Has anyone else had this problem before if so how did u fix it thanks for replying and helping it is very much appreciated
