clutch issue
moronthr33
195
Oct 7, 2010
Aberdeen, Maryland
My problem is that when pushing down the clutch it goes easy till about half way then feels like it's hit the floor press harder then it will go all the way down. A little history i bought the car as a shell i've put the motor and trans together dropped that in then replaced the master and slave cylinder and i have a ss braided line from russel that goes from the end of the metal line to the slave cly. ive properly bled the whole system and properly adjusted the push rod on the master cly.
any info is appreciated
Thanks
Kenny
Did you check your throwout bearing? Maybe it needs greased up or even replaced?
I got same problem, I just pulled the engine hoping to find out. Seems that my engine has a aluminum flywheel, idk if it's related. I'll update today, because are problems are similar. Guess has a stage 2 clutch also.
