Clutch issue
SeanCollins
134
Apr 23, 2011
Tully, New York
Ok so I was driving down the freeway in 5th around 75mph and noticed my clutch drop slightly. I didn't think much at first.. I was still able to shift fine up and down.. I pulled off the freeway and Sitting at the light hear a very strange sound around the rear end.. It was almost like a grind or sputter.. By the time I got it parked it was almost jumping in and out of gear.. I'm a at the dr now with a car I'm not sure will make it home any ideas?
So I'm in the parking garage and the car won't move right. If I put it in fear and floor it I can go like 3 feet all the while it's jumping and bucking and sounding like the bottomed is about to come off.. Now what?? Had it 4 days and this BS already I should of stuck with my VW
Start with t-case as I stated earlier and if that is fine it may be the center diff. Were you running the car hard prior to the issue?
Cars up on a lift and got the t case off and teeth just dropped to the ground.. Looks like it blew a seal and dryer and burned out.. Hopefully that's all it did.. Te guy who sold me the car says he has another one I will pick up in the morning and hopefully get her back on the road. Thanks dot the help guys this forum is the tits
