clutch issue i believe
lockout
50
Dec 6, 2008
concord, Michigan
i just bought a 90 gsx awd and when i press the clutch in its fine but as soon as i let it out even just a lil like a 1inch or two the car engages .sometimes it shard going into first or reverse or will grond going into these gears. BUt if i let it warm up or start in second for a bit it'll drop into all gears no problem. its a 5spd.
thanks guys
josh
Very true i am having the same problem in this michigan weather. Try not to drive it with a weak clutch. Improper clutch disengagment really does damage to transmissions. I just let my car warm up and pump the pedal and the lines warm up and i get a good pedal.
i'll bleed it tonight and check rod adjustment...thank you....if its my snycro's any good site to buy one under a grand?
If it goes into gear when warm, chances are your transmission is ok. You could change the gear oil for some peace of mind. I recommend a 50/50 mix of Redline MTL and MT-90.
If you absolutely believe that you need a transmission rebuild, several reputable shops (and sponsors of this site) are Jack's, Shepard, Dogbox.
TRE they do rebuilds under a grand if you get just syncros. I paid just over 1200 for my build and it is stage 2ish.
Yea definitely sound's like you need to bleed your clutch and adjust pedal play. There's a good thread in here on doing it with one person instead of two.
all the web sites i've gone to ask what "spline" is..is there a way to tell without removing my tranny..
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
