DGajre777
DSM Wiseman
- 4,772
- 133
- Jul 16, 2004
Orlando,
Florida
Current mods are listed on my profile, car has 57xxx factory miles. I bought the car with 52xxx miles.
The car had a new stock clutch installed at 42,000 miles. The flywheel was resurfaced and the clutch master cyl was replaced. Before I installed the Apex'i N1 I replaced the clutch slave cyl since it was leaking.
I do NOT have a boost gauge or a boost controller and I have no idea how much boost I'm running. I know that if I run over 15psi, the clutch will go out eventually, but I'm nore sure if my problem is due to my car running higher than 15psi boost. My next mod is a speedhut boost gauge and hallman boost controller.
I bought my Apex'i N1 catback about 2 months ago. After I installed it, it seems like I have a lot of low end torque. If I launch my car at 2500RPMs, it launches good, but if I launch it at 4500RPMs I can smell my clutch/flywheel burning after the launch. Is this normal??
I normally let the car sit for 10-15 minutes to cool down after I do a 4500RPM launch. Any ideas?
, I know from experience. I wouldn't worry too much about it though, all it's gonna do is fry the disc, maybe warp the pressure plate a little. You will swap it out eventually i'm sure so that will all be replaced.
But I now run an ACT2100 with a 6 puck sprung hub disc.
, shows how much attention I'm paying, doesn't it. It was back up with new posts and I didn't pay any attention to when you started it. Sorry.
