Clutch difference between ESi and TSi
Jeremoose
859
3
Sep 28, 2004
Edmonton,
Hi, my last thread was kinda stupid, so i'll follow up with a real question: is the clutch stronger on a TSi as opposed to an ESi?? Because when i had an ESi I burned 3 clutched in less than a year, so i just wanted to know... So i guess my real question is: is my clutch the first thing i should change out? Thanks all!
P.S. i DO drive my cars pretty hard if that changes your mind :p
You would think with some common sense that the turbo clutch would be stronger considering it's holding more horsepower from the factory...
Well that's what i thought too... But i can "think" all i want... What i would like is to know for sure..
year?
If it is a 2g then yes they are different for sure. Call the parts store for your year and see if the part numbers a different. If they arn't then dig into the question. If they are different you have your answer.
