Clutch choice for longevity?
4g64gs
Dec 18, 2010
Chester County, Pennsylvania
DSM community, I need your help. I have been reading every thread on here that says "clutch", and there are nothing but conflicting opinions. What clutch kit, or combo, should i go with if I'm planning on having my clutch last? I'm not a track person, but there will be some occasional launches. I have not found a thread that suggests a clutch with longevity as the priority.
My car is set at 16lbs on the stock t25. Thanks for any help you can give me.
IF you want longevity,
1.Don't dump your clutch or race your car
2.Be the only driver
Best advice would be when you replace your clutch replace everything, make sure your flywheel is machined correctly. Replace the fulcrum release fork, OEM throw out bearing, then for good measure I would do the master and slave along with since your a 2g get rid of the crappy accumulator on the clutch line.
I did all this on my 2g when I had it then went with an ACT 2600 never had an issue and I was pretty hard on it. I put over 15k on it by the time I sold it.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
