Clutch adjustment issues.
Coup D E'Tat
1,960
8
Dec 22, 2002
Pittsburgh, Pennsylvania
Newer master, slave (supposedly,) pivot ball, fork, TOB, and 2600. There is a washer underneath the pivot ball, but I can't remember how thick it was. System was bled properly.
With the clutch adjusted nicely, so that it grabs close to the floor, the car does not want to go into gear with the motor spinning. When I adjust it back out, it's fine, but it grabs too far off of the floor for my taste.
I don't remember it doing this at first, when I put the 2600 in. It seemed to start acting up maybe a few weeks ago, until I finally adjusted the clutch again.
Am I missing something simple here?
Adjust it so the clutch engages a couple inches off the floor. As you have found, if it's adjusted so it engages right off the floor it won't shift good. If the engagement point is too high the clutch might not grab with full power.
