2G Clicking noise
605jdm
169
14
Feb 7, 2016
siouxfalls, South Dakota
Every time I put the gas peddle in our take my foot off the gas there is a clicking noise that sounds like it is coming from the center console. It doesn't matter if its 2% throttle or 100% is clicks one time and I can't figure out what it is.
Like a relay clicking? Or like metal hitting metal, or like ebrake click? What about driving with the console pulled out, it should makemit easier to pinpoint
If its coming from the front of the console, like under the radio, the fuel pump relay and mfi relay are there. Power door lock relay should be in that area too. So is the ABS G sensor on AWDs but I dont know if that can click or not
Pull the fusible link for the ABS (enginebay fusebox) and see if it still makes the noise.
I say pull the center console and drive it, it should be way easier to figure out. Get someone else to go with you and put a finger on the relays, you can feel when they click on
