Click Here.
DSMfânâtic
111
Oct 30, 2003
Warren, Pennsylvania
Does anyone have any suggestions on loosening up the clutch lines for a stainless line install? I cannot get the line under the fuse box to loosen up. I am using a 10mm wrench, and all it is doing is rounding it off. I've soaked it with "PB Blaster" at least 6 times. I'm out of ideas and about 5 minutes from busting out the vise grips.:thumbdown
Thanks
Brian:dsm:
Your putting in a Stainless steel line? If you are then cut the lineright before the nut and throw a socket on it.
You have to use a Flare Wrench, else you will just round it off.
Well, the line was already round from using the 10mm so the vise grips did it.....I'm warmin my hands then its back to the snowy driveway to bleed the clutch...Yaaaay!
Moderator: you can close this thread. Thanks
