Clean my Head?
Spyder4g64
356
Mar 9, 2005
Wallingford, Connecticut
This is kinda a dumb question but i just took the head off my car and took the entire head apart. Now what do i use to clean the inside out... theres lots of metal shavings in the oil at the bottom (i kno thats bad)... help me out thanks :thumb:
Yes, take it to the machine shop. They'll easily be able to clean it up for you and tell you if the head is warped or needs new seals, etc.
It's definately a good idea anytime the head is taken off.
Alot of people soak parts in Purple Power...(deluted in a big tub) cheaper then varsaw (sp,aka.parts washer fluid). A couple of guys I know have done this and it makes it look new. Just let it soak over night. Remember tho its going to harden all your valve seals- should replace anyways. And when you reinstall it that it needs to be lubed back up.
Matthew
All the seals, guides, seats and stems are out. I dropped it off at my buddy's shop and he said he'll clean it for me, free. Ill let you know how it turns out. Thanks for your help.
