choppy rev
2geezy98
Jan 17, 2013
springfield, Massachusetts
I installed a new tranny on my 95 talon tsi and removed the egr , canister and all vaccum lines and on my first start up car idles fine then when I try to rev it to 2000-2500 it revs but very sluggish need help no boost leaks but its running like it has one
By check maf you mean what . its plugged in and its clean and couplers are tight and Evey line is where it needs to be . is there a way check thru link v3
When its at idle on the wideband its running very lean 18.0 + flatlines the wideband so I shut it off when I rev it goes rich
It fires rite up no problem and yes it does make a difference with maf unplugged .idles bad unplugged but plug it back idles fine but still wicked lean
Never actually did a BLT cause I've never had one and how could one come out the the blue if the car just sat for a few weeks
I removed the canister only and looped the egr but I figured looping it would work I ordered the plate should have it in a few days
Did the blt found a few leaks but the cause of the choppy rev was the firing order on my spark plug wires was mixed up car is good now thanks again for the help ....god damn spark plug wires LOL
