chirping sound
gsxeclipse97
1,255
Nov 7, 2004
Cedar Park, Texas
I have this strange sound that i can't figure out where its coming from. At idle i there is no noise but above that i can hear it. It seems to increase along with the rmps. It also is rather loud I can hear it with the windows up. And when i roll them down it is really loud. I thought it may be a belt because i just replaced one but that doesn't seem to be causing this noise. It just started doing this a couple of days ago. I have never heard this noise before so im at a loss for words to even compare it to anything. Any help would be great
thanks..
volume does increase as rpm's but, then it levels off somewhere and doesn't anymore. No it doesn't when i am turning but at 65mph it is very loud. The pitch of the sound seems the same to me it just decrease when rpms drop. If i am down shifting the sound will go away but soon as i get it in gear again it comes right back.
The harmonic balancer is most likely and easy enough to check. Just get down there and check for cracks or general signs of wear.
Any "chirping" sound like the one you're describing is gonna be coming from your belts, so just start checking there. Removing accessory belts until you figure out the noise. My $.02
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
