Left turn chirping sound?
tranman91
190
9
Dec 29, 2003
portland, Oregon
i was hoping someone here could help me identify this sound...
when i turn left i hear a chirping sound coming from the front passenger wheel area?...like a little bird...and only on left turns...
anyone have any knowledge of what this could be?...
thanks
check your brake pad wear indicator. my car did that same thing to me and it tured out that my pads were worn, I could never figure out why it mad the noise only when turning, I just figured it was cuz the caliper or somthing might flex or somthing when turning. let me know aight good luck. [--->Matt<---]
i appreciate the input dude...
as i went out to check my pads i was about to get really pissed if they were worn down cause the pads are less than a year old...rotors as well...i don't drive that hard either.
everything checked out ok...unless the rotor has a hot spot or is warped?...maybe a very early sign of the cv joint going out?...i don't know...the whole left turn thing is confusing me.
thanks again...
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
