Check for boost leak?
I went to Home Depot today to buy the stuff for the tester, I got the end cap and the hose...but I can't find the valve stem. Where can I buy the thing?
PepBoys, Autozone.......look for "tire valve stem", get the rubber type so you can drill a smaller hole on the end cap and squeeze the rubber valve stem through for a nice tight seal.
Yeah I ended up using a quick disconnect. Anyways I did the test and I fixed two of the leaks at the inlet and outlet of the ic. I was surprised that there was no leak at the compressor outlet, but I coudn't fix the leak at the throttle body. It's leaking pretty bad at 15psi on the side of the tps (probably because of the flange that comes with the dejontool pipe).
I did end up on one occassion blowing the end cap off of the tester because the compressor tank we have is only capable of 40psi minimum.
