Check Engine Light!!!
brane_97talon
134
20
Nov 13, 2009
Inland Empire, California
ok, so i jus put a freshly rebuilt motor in my 97 talon. cranked it, and the CEL came on. come to find out i had two codes pop up : p1494 (mechanical fault) and p1390 (timing skipped a tooth or more). i fixed the p1494 but the other code will not go away. mechanic assured me there was no way the timing was off....### do i do???? i need to get it smogged! ps. car runs lyk a champ....
you timing can be off by a tooth and still be driveable, do your checks with someone else to get another opinion if you dont trust him your your own.
well, i trust that the timing is right. also i even had the code cleared byt the OBDII scanner and it still comes on....would disconnecting the battery work, if that doesnt?
