Check Engine Light
solarstorm24
Oct 4, 2005
Bronx, New York
I have searched the forum and have not found the answer. On Saturday I started to do the simple mod describe as a stage 0 and 1. I did as instructed. I removed the Negative Battery cable. I then removed the BCS Restrictor. I then installed an Injen Short Ram Air intake kit for my 1997 GST. Everything worked fine. I Monday I was driving the car and all of a suddent the check engine light goes on. The check engine light has never turned on my car before. Could this be because of the removal of the BCS restrictor or because of the Air intake? Or could it be something else?
You don't remove the BCS without a boost controller. Go get the codes ran at a local auto parts store and post what they are.
According to the Tech guide of this website it stipulates the following "Step 7: Remove the BCS Restrictor If you do not have a manual boost controller, you can safely up the boost about 1-2 psi by removing the restrictor in the boost control solenoid.
As said, get the codes read. We're not going to play "Guess What?" when the real answer's five minutes away from you.
If you pulled the BCS from its electrical harness and didn't re-connect it, that will throw a code. But we've been lured into these snipe hunts before.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
