Check Engine Light popping up
DaOnE51T
88
Jan 17, 2004
Queens, New York
I recently removed some of the vaccum off of my car which includes:
The vaccum tubes mounted on the firewall
The vaccum tube tray mounted under the intake
I "U" the throttle body vaccum
Blocked the EGR with sheet metal
Now my Check Engine Light is popping up after 30sec. I checked the battery terminals and it still did the same thing. I put my datalogger on and there is knock during idle now. What do you think it could be?
- Problem
- Check
31
- EVAP
- solenoid circuit Evaporative purge solenoid / Clogged purge line / Vacuum hose / Evaporative emission canister clogged
31
- Evaporative purge flow monitor failure
- Evaporative purge solenoid / Clogged purge line / Vacuum hose / Evaporative emission canister clogged / You're Turbo with a 97, 98, or 99 2GNT
Taken from http://www.2gnt.com/nuke/modules.php?name=Sections&op=viewarticle&artid=8
MuddinPede said:
- Problem
- Check
31
- EVAP
31
I have a 1g
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
