Check Engine Light Codes?
cody95talon
Jun 1, 2012
Burnsville, Minnesota
Hey everyone. So as i'm getting ready for my turbo replacement tomorrow, I just thought about my 95 talon's check engine light codes. I figured maybe I could fix some of these while in the process of replacing my turbo, the codes are:
P0141: O2 Heater Circuit (bank 1, sensor 2)
P0125: Insufficient Cooling Temp for Closed Loop Fuel Control.
P0170: Fuel Trim (bank 1)
Since I first used an obd scanner to get these codes, the O2 sensor has been replaced, as well as the thermostat (if that helps anything), and water pump.
I couldn't really find any information on what these problems might be, so any help would be greatly appreciated. Thanks guys! :thumb:
Did you get anything back or have you solved the problem? I would like to know, then you could resolve this thread. Thank you...
The car is not running right now and I am in the process of swapping the turbo with complications, cannot pull the codes until I am finished with the turbo, I appreciate your help though, I will try and get the codes again as soon as possible.
