cheap wideband controller!!!
Status
Not open for further replies.
notsofastdsm55
61
Jun 20, 2007
kailua, Hawaii
I was searching through a honda forum to help burn a chip for my friends integra and I found this http://www.14point7.com/JAW/JAW.htm seems pretty sweet although you'd have to buy the bosh sensor and make your own cable but other than that looks pretty good! what do you guys think?
Nice find.
Just want to point out that you can pick up AEM UEGO's brand NEW for around $200 shipped on ebay now. From major vendors too!
Considering it has 2 programable outputs you should be able to set it so that it mimics the tech edge wide band(stoich=2.5v) and select tech edge wideband in dsmlink. or you could progam it to match pretty much any controller so long as you know the controllers specs(what voltage is stoich) This guy started developing it awhile ago and now he is producing them with or without a display and he sells it as a DIY kit!!! freakin sweet!!! I thought I would share my find with the dsmtuners community and it looks like it was well recieved!! oh yeah I am in no way affiliated with this guy just was searching around cause I am a cheap a$$
Compatible with dsmlink?
Not sure, doesn't look like it will be based on the info below since the volt to A/F mapping will be different. Anyone agree or disagree?
"Can I make the analog outputs the same profile as PLX, Innovate, etc...?
Some wideband readers have a built in voltage offset of about 1 volts positive on its analog outputs, so if you set 1 volts output the actual output is shifted upwards to about 2 volts. JAW does not have this voltage offset, so an entry of 1 volts means the actual output is 1 volts with respect to the ground signal that JAW is hooked up to. To make JAW so that its analog output behaves like other wideband readers, add the offset voltage to each voltage entry. I am not sure exactly what the offset voltage for each brand of readers are, I suspect that they are about 0.7 volts."
http://www.14point7.com/JAW/FAQ/JAW FAQ.htm
Offtopic - the cheapest wideband on ebay is the Innovate standalone wideband with a Bosch sensor for $170 shipped which can be logged on DSMLink. After you buy this kit and a bosch sensor you may end up saving some money (not a lot after you end up getting wires, connectors and cases).
the NGK AFx is pretty cheap too, ill be installing it on a customers 2g spyder..ill report how the install goes.
I just checked on the site under the section where you can download the exe. the latest one 1.13 and up have lc-1 outputs as a preset option so no need to program them!!
So if you figure in the cost of the device. $60 Assembled: Without Display (Ill be using dsmap and don't need a display) bosh sensor $50-$not 70 and making your own cable(only cost money if you choose not to use crimp on spade conectors) it comes out to about $110-$130 for a complete setup! or cheap if you build it yourself!!
The developer offers group buys of 10 or more but the discount is 5$ off without the display and $7.50 with display. so whos up for it!
Interesting post.
You might want to edit your post. Group buys are not allowed to be started by members, just vendors.
My apologies, I didn't mean it in that context(referring to the group buy) I am not the one whos offering the group buy, I was just merely stating that the develper himself offers them. Ill go ahead and edit my post if you want!
I was just trying to save you from getting warned by a moderator, it is really up to the moderators to enforce the rules.
Status
