Characteristics of a Blown Head Gasket.???
TurboKID69
47
3
May 1, 2005
Manteno, Illinois
What are some hints that id ill have a blown head gasket..?? i got oil everywhere and my car started to smoke..???? get back to me.. 97 gs-t :dsm: HELP
Blown headgasket:
Blue or white smoke
overheating
blowing out coolant from the coolant reservoir
bubbling in the coolant system
excessive pressure in cooling system
oil in coolant/ coolant in oil
low compression
When you say you have oil everywhere, what do you mean by that? Just all over in the engine bay?
Check your intercooler/IC pipes to see if oil is in them. If there is, I would suspect a blown turbo.
What color is the smoke?
well the car seems like there is a loss in compression because when i get on it it doesnt pick up and it sputters.. the oil was all over the engine bay on the valve cover battery and around where the head gasket is.. I didnt really see the smoke cuz it was at night and i dont wanna drive the car anymore because i dont want to mess n e thing else up. But my coolant level has been the same and it looks the same. But i took the car for a test drive the other day and it started to smoke white i think.. LOL but i opend the hood and my oil cap was off.. :confused: but i also hit a bump and i could of forgot to screw it on tightly.. but there is not oil around the ic pipes or near the intercooler.. and there is no oil near the turbo...
but there doesnt look like there is a leak from the valve cover..??? but could that cause other problems??
