changing transaxle fluid
Eclipsionz23
134
Nov 10, 2003
Tulsa, Oklahoma
is this gonna be a pain in the ass like i think its gonna be?? the location of the filler and the drain plug seems backwards to me. in the chiltons it says that the filler is at the bottom, and the drain is at the top?? just thought id get some quick help here before i do this, because where youre suppose to fill up at, theres no room what so ever unless youve got something rigged up out of a squirt bottle.
eric
When you fill it up, you should use a tube that goes into the fill plug.
I bought a transfer pump at Autozone.
Suck the new fluid into the pump. Insert hose into trans, pump fluid into trans. Repeat until full.
