Changing transaxle fluid in gst
titusmangum
Jan 16, 2006
Fuquay Varina, North Carolina
I have a 95 gst and I'm trying to put new tranny fuild in but I can't seem to find where it goes. I looked at the manuel but it showed an weird pic that I couldn't make out, but If anyone could give me some insight that would be great.
thanks
if its a manual there is a bolt you will have to unscrew to check the oil. you will also use this hole to fill it up with fluid. To drain there should be a smaller bolt on the bottom. Once you get under the car youll know what to do!
