changing timing belt harmonic balancer on?
4g63eagle
151
Nov 3, 2009
arozonoo, Africa
i was reading that i can change the timing&balance shaft belt with the harmonic balancer still on the car just the 4-12mm bolts taken out not the center bolt? is this true?
The 4 bolts hold the harmonic balancer on, the center bolt holds the crank sprocket on. You don't have to remove the center bolt but the balancer has to come off in order to remove the timing cover.
:banghead: LOL :tease: i feel like the special kid now i gave that big bolt my best shot today but my impact is a lil tired and it wouldnt budge it i had the little bolts loose i just didnt take them all the way out stupid me thank you so much for clearing that up for me :thumb:
If your going to change your balance shaft at the same time you have to crack the crank nut. you have to take it off in order to get the balance shaft belt out. To crack it all I did was put a breaker bar to the ground and turn the car over with the starter for a split second. my impact wouldn;t get it off either.
