changed plugs/wires and still misfiring!?
blackjdm90
88
Oct 1, 2008
Vail, Arizona
Hey everyone, i changed my spark plugs and spark plug wires today and i am still misfiring when i hold my car at a certain rpm and at idle i can hear a little bit of a misfire. i am beginning to think that my transistor unit is bad?? i also had to change my alternator and i wouldn't know if that would cause anything like that to happen on my 90 tsi? if any help thanks!!
but what makes me think it is my Power TR unit is that when my car is started and idling i wiggle the wires around it and touch the transistor pack and my car sounds like it wants to die and the idle changes and the more i mess with it, the more i have to adjust it to get my idle right.
You're on the right track checking the ignition system. It doesn't sound like a fuel issue to me.
Have you done a boost leak test? You might have some vacuum leaks that are causing a misfire. Does it do it all the time or only when the car's warmed up?
well somedays it is not bad like 2 days ago. but today it is ridiculously hot outside and when i took my girlfriend to lunch it was doing it bad. pretty much whenever i gave it gas and so i stopped at a gas station and pushed down on the transistor pack and it helped. i was told one time that to test if the Power TR unit is bad put a heat gun or hair dryer to it and see if it changes anything. and with this heat i bet its making it worse... and i am checking my boost leaks soon. thanks
If you need the power transitor check this link I saw they have a 1990 power transitor for $39.99 shipped.All the parts listed are in stock and ready to ship. MAKE SURE YOU CLICK THE BUY IT NOW LINK ON THE TOP MENU OF PAGE FOR THE CURRENT PARTS IN STOCK AND READY TO SHIP
Mitsubishi Graveyard
A+ haha i found one for 29.99 on ebay plus shipping so cool i'm saving money. i'll let you guys know if it changes the problem i am having!!
RESOLVED!! Ok I ordered a new power tr unit and put it in and the idle was a little better and when I would wiggle the wires on the new power tr unit my car would not die, since it would do this before I thought I fixed the problem. Anyways I was not out of the woods yet, so I started to leave my garage and all of the sudden it bogs down again and is misfiring like no other! So I then start working my way through the ignition system starting with the spark plug wires, I put new ones in and started it and once again I had not fixed the misfiring. I then pulled out my coil pack and began to look at it. Since it was cylinders 2 and 3 that was not getting good spark, I checked those first, I popped off the little black covers to the threaded studs under the pack for 2 and 3 and i saw it! The wires that were going into the studs with a bolt were so loose and wobbling around that there was not a good connection at all. So I pulled out a little 9/32" (or so) wrench and tightened them. Fixed it like a charm and now my car does not misfire at all when I give it full throttle or just cruising!
p.s. Sorry about the long message to explain such a simple fix. ;)
