center diff blown
dsm mad man
89
Dec 3, 2004
marriottsville, Maryland
i just pulled my trans apart for my 1990 awd and the center diff is done. where can i get a new one, cense my trans is apart what els would i be able to upgrade to be a little better for my motor set up. the motor is verry modded and i have a 6 puc act clutch.
You can go with a welded or 4 spider unit. Which lower diff housing do you have? Look here:
Gear set identification
In the bottom pic, is it the one on the right or left? Did you damage the center diff lower housing outer gear? If you have the unit on the right, I have a few of those housings in stock.
I can weld your diff for $100 or convert it into a 4 spider.
Jack
yea i have the one on the right, i dont think the outer case is damaged i didnt want to take it all apart because i dont know the thorque specs to put it back together. plus this is the first trans iv taken apart. what do you sugest i do
It's up to you, but you can ship us the center diff and we can rebuild it for you. We can do an OEM rebuild, 4-spider, or welded unit. I have many of the lower housings in stock (used) that I can sell for cheap if it turns out yours is bad.
Jack
