Cel P1600
redgst89
Jul 10, 2007
colorado springs, Colorado
Okay well i have a 97 gst with a auto trans. I got a cel the other day, so I went to autozone to get the code pulled. They came up with this:
P1600 serial communication link malfunction with tcm.
Does anyone know what should I check? Or does anyone else have this problem?
is the car running fine ???? did they clear the code ? and if they did , did it come back on ?
Check to see if you have the original trans/ or trans control module in the car.
The pcm might be looking for a different trans or module than the one that is installed in the car.
Just a starting point.
Or make it easy on yourself and save up for a m/t conversion!
Ok so everything checked out ok the ground was ok but i still cleaned it up a bit, a little rust on the plate the wiring harness was fine when i went through the pin voltage testing. but when i pulled the TCM and cracked it open to take a peak it smelled burnt, and looked as if something was leaking.
