cruisintalonawd
- 1,313
- 2
- Oct 18, 2007
Casper,
Wyoming
could this be something along the lines of lean or rich while cruising and all good under WOT or what????
Well I bought a logget but its not working ill try to get a shop to run the code tomarrow
Now on my logger I notice that my TPS isn't reading until about 3/4 throttle and the hight percentage it will go to is like 98.6.
Could this mean my TPS is bad?
ok thanks I would pull the codes but I cant get anyone to pull then and i was told my logger doesnt have that option
i have the exact same problem. i took it to the shop today to pull a code and got
-TPS signal out of range
-Intake air temp circuit problem
-baro pressure sensor circuit
could a bad MAF be causing this as well?
can a bad MAF cause the TPS to function incorrectly?
and is the Barometric Pressure Sensor also in the MAF?
