CEL help!
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
I just got back from auto zone and had them do an ODB tp scan for my check engine light and there were 4 codes that came up!
1- P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
2- P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
3- P0171 System too Lean (Bank 1)
4- 1390 this one they said was a dealership code ?
please help guys
P0351 The cam/crank sensor problem can set the coil code.
P0171 Means your CEL is most likely caused by a bad O2 sensor.The ECU senses this as a lean condition and attempts to add fuel to compensate for the "supposed" lean condition.
P1390 Timing Belt Skipped 1 Tooth Or More.
Check this thread out it may help you with your problem.
http://www.dsmtuners.com/forums/showthread.php?t=198509&highlight=P0351
Code po171, my o2 sensor is new Its a bosh type. I just bought it about 7 or 8 months ago. Do u think this code could be caused from not haveing a catalytic converter? Right now im running straight pipe.
UPDATE: k a strange thing happend tonight, I went to a friends house to get a new cam sensor and when I got there he wanted a ride so I took him on a short ride and showing him what my car can do. So I got on it pretty hard and then right after that I noticed my CEL turned off!! The motor has about 550 miles on it and its the first time its came off!
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
