2G CAS sensor broken wire
Can I splice the white into the blue red?
No, you need to reattach it to pin 1.
There is how a 1G CAS is connected on a 1G. The white wire on pin 1 is for the cam angle signal, The black wire on pin 2 is for the TDC (crank angle) signal. The red wire on pin 3 is the switched +12v power and the black wire on pin 4 the ground.
On a 2G with a 6-bolt swap the 1G CAS is often wired like this. Ignore the yellow wire color it's still the crank sensor signal on pin 2. The actual wire colors will depend on where the connector came from but you need to make sure the correct pins are wired to the correct places.
That thing looks mangled, get a whole new connector and be done with it. BTW, it's not the original connector for a 2g, that's a 1g cas.
I fixed it I was confused because people are telling me car won’t start with white disconnected it runs fine but is the white used or not anymore?
Not only is it mangled but it look like some of the wires are solid copper not stranded and the ground wire has broken insulation.
2G's have two individual sensors where a 1G has them combined in it's CAS. When you swap a 1G engine into a 2G you have several choices to make regarding how and where you get the Crank and Cam information from. Mixing and matching 4G63 parts only makes this more convoluted like running a 1G head on a 2G block or a 2G head on a 1G Block.
Both early and late 2G's 4G63s have a crank angle sensor mounted on the front of the engine by the crankshaft. If you have a block that has the mounting points for this sensor it common to continue to use it. 95 and 96 2G's have a cam angle sensor mounted on the timing belt side of the head under the intake cam sprocket where the later versions have it located on the clutch side of the intake cam like a 1G CAS is located.
The three pin connector you show looks like the 2Gb CPS with it's Black, Blue/Red, and Red wires. The Red and Black wires are switched +12 and ground. The Blue/Red wire is the Cam Angle signal from pin 88 on the ECU.
The Crank Angle Sensor on the front is also a three pin connector triangle shaped with Black, Blue/White, and Red wires. Like the Cam Angle sensor the Red and Black wires are the same switched +12 and ground and the Blue/White is a crank angle signal.
In you video you say that there was a blue wire in pin 1 but I suspect that just not knowing how the pins are numbered because it looks like the open spot on your connector is pin 2 which would be the Blue/Red wire from the ECU..
You'll note again that the 1G CAS can provide both cam angle and crank angle signals. You don't have to use both when swapping depending on what parts are being used. Pin 1 on the 1G CAS is the cam angle signal and if you are using the CAS to provide that, the wire to pin 1 would connect to the wire that was on pin 2 of the 2Gb cam angle sensor connector. (the Blue/Red wire connected to the White wire in pin 1 of the 1G CAS connector.)
If you also needed a crank angle signal, 1G CAS pin 2 would be connected to the wire that was in pin 2 of the front crank angle sensor connector. (what looks like a Black solid wire might run to the Blue/White wire from the crank sensor.)
Thanks I soldered them back in pig tail is coming in the mail I didn’t do the swap I’m fixing a mess of a car
From your other post it was clear you got yourself a basketcase, so I'm trying to give you an idea of the resources at your disposal and some of the issues you'll have to identify to be successful along with enough information so you can figure it out.
Some of the things
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
