Partially Bad 1G CAS sensor
teamitr
100
Jun 14, 2005
Riverside, California
I was having problems with my 2nd gen 6 bolt swap not running right in full throttle. But regular driving and the IDLE was perfect. I tried checking everything from timing marks,boost leaks,CAS 180 degrees off... So after checking everything I changed the CAS sensor and Problem solved it ran beautifully.
I just wanted to let you guys know since i was searching and never found anything about a CAS not semi-working.
when you would drive it at full throttle, what would it do?? maybe my cas is bad too.
IT would feel like if you were running really rich and not go no where. and the engine struggled to get to the higher rpm's 4000 +. Boost was there but it feels like some thing is holding you back.
I'm getting the exact same thing.. rpms slow to build.. sluggish.. feels like there is a loss of power. I'm also getting a high knock count during this. Could a bad CAS cause knock?
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
