cas install???
I don't think you have to change the CAS. That is a 2G 6 bolt swap thing. Only difference is if your using a 90 CAS, in a 91+, you will most likely have to hardwire it in unless you make\find\buy a harness that is plug and play.
The 93 should have the black top CAS, which is said to be better so use it if you can. IIRC it is a hall effect type sensor.
i dont really wanna wire anything up so i might as well put the cas on that will wire right up, and like u said i heard that it was better too so why not use it
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
