cas question
wags122
81
6
Jan 19, 2005
Snohomish Co., Washington
My cas on my 7 bolt is bad but i am in the middle of a 6 bolt swap and i do have the 6 bolt cas. I plan on running a 7bolt head and a 6bolt block, do i need to run the 95 cas and the 6 bolt cas or am i fine with just the 6 bolt cas. Thanks for your time.
Since you have gone to a 6-bolt block, you will need to use the 1G CAS, and wire it in to your 95's cam angle & crank angle sensor plugs.
The only way to use your 95 can sensor would be to adapt the 6-bolt block/oil pump cover to accept the 2G crank sensor. It is eaiser just to use the 1G cam sensor.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
