Car won't turn over
bartels903
2,052
Dec 3, 2004
Gahanna, Ohio
So, I changed out my headgasket after blowing it. I put everything back to where it should be, and now it wont turn over.
1.I have spark and fuel.
2.Changed out my ecu for a known working one, and still didn't help.
3.No leaky caps.
4.I went over all the electrical plugs, and I'm sure they are all plugged in.
5.Checked timing, might be off by 1 notch, but I don't think that should make it not start (having timing redone by professinol I think I screwed it up, and don't have much time anymore)
So what else should I check?
bartels903 said:
How would I go of checking this? These CAS's are so complicated in my mind.
Did you seperate the CAS from the head during the HG job? If so, unbolt the cas and rotate it 180* then try again.
Yeah I did, Ill try this tommorow. Should I just flip the whole thing over, or just turn the inside part?
Sorry for the newbie questions, I don't get these things.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
