car won't stay runing help
nitrokid
78
Jan 23, 2009
lincolnton, North Carolina
OK the 94 eclipse gst I just got it my first turbo car has some bug's and their starting to piss me off a little. The car runs pretty good until it warms up then it has a hard time idling and if you rev it will cut off it wont go back to idling. also while driving one you push then clutch in it will cut off it you don't pull it back out real quick. I changed the I think it's called the closed throttle sensor anyways it's the one that sits rite over the throttle cable on the throttle body. Then it ran fine for a week then tonight it started messing up again.
Another thing the car does is at half and wot once it it start's boosting it slightly bucks and stutters. Please help guy I'm out of idea with this one and this thing is going to be my dd after this Thursday so I need to get it fixed quick.
One more thing what should this car idle at?
also sorry if my grammar suck's.
Do a boost leak test that would be where I would start... Could be a boost leak fix that and it may fix it all... I'm pretty sure it's a boost leak, my car bogged and sputtered as soon as I went over a certain amount of boost too
