car won't stay on?
dsmotors95
93
Jun 16, 2012
spring valley, California
so my car jumped timing out of no where and bent my valves.i fixed that problem and set timing but it still wouldn't start.found the CAS was broken so i replaced that,still wouldn't start then i saw that my CPS was also broken so i replaced that as well but it still wont start. before i replaced both sensors i wasn't getting any spark on 2 of my coils, so i replaced the coil pack and the PTU. i haven't checked if I'm still not getting spark there but I'm guessing i should after the CAS and CPS install. i need some help on what else to look for..
i forgot to mention after the CAS and CPS the car will start but wont stay on,it dies within 2 seconds.
If you put in a 2gb ecu in a 2ga you need to swap the coils. I dont know the order but it would be reverse of the 95 eprom ecu dsmlink into a 97+ car.
Also auto vs manual or gst vs gsx doesnt matter with ecu.
