2G Car won't run right 2g Eclipse GSX
jdmfairladyz
May 3, 2014
elgin, Illinois
Ok so I just replaced the crankshaft position sensor and the reluctor disk. I put it back together and it ran fine for about 10 min but when I got to around 6 psi it would not go past it. Now the car will not go over 35 MPH. There is a crack in my valve cover could this cause my problem? Also does anyone have some correct fuel trim maps for a 2g GSX with a 14g ported turbo?
Thanks
what happens when you try to go over 35? Does it feel like your hitting a brick wall? Does the car boost fine up to that speed? Anyway to post a video of what its doing and how it drives? What did you take apart to replace the crank sensor?
