car starts a little rough, give gas and dies
blizz99
1,010
11
Sep 21, 2005
Zeeland, Michigan
Ok, so I finally got my car running again but now there's a new problem. When I start my car it starts up a little rough. When I rev the engine it stalls out. Could it be that I'm running stock fuel pump w/ 550cc injectors and Aeromotive FPR? What could it be?
Do you have idle surge? you might have a bad isc because when you let off the gas the engine goes into decel. mode and cuts fuel, at 1500 rpms the fuel should kick back on and either idle good, stall, or try to stay running but shakely.
I don't have idle surge but what you described is on point. So most likely its the isc?
I once had a similar problem after I accidently ran out of fuel. You said that you just got your car running again, so I would not be suprised if maybe you are picking up some dirt from your gas tank. That will clog your injectors, at least it did for me.
You can take the gas tank off and clean and drain it. I do not know how to do that or what precautions you need to take, but, I would recomend for anybody that has this, to have your injectors cleaned and to make sure you do not run out gas. Alot of cars have dirt in the tank, it just sinks to the bottom, no big deal, just keep an eye on your gas level.:cool:
how long did the car sit without running? if u are very low on fuel, maybe fill it up with fresh fuel, this may dilute any sediment and or old fuel in the tank. also if u haven't done so, change the fuel filter to make sure the fuel is being filtered properly.
