Car runs horrid...
PropXprt
431
Oct 19, 2002
Springfield, Illinois
Mods in profile are current... I did a boost leak test and do have a leak somewhere but, not so bad that it would make it run the way it does. I also did a compression test last night and got ~140 on all cylinders. Put new plugs in today as well, ngk's. The problem is as soon as I put the car under any load you can feel it start to lose power. Maybe you all can find something obvious about the log I have attached.
Timing ft02 02 Hz rpm knock Inj. Pul Inj. Duty
28° 70.2% 0.14V 257.9Hz 3063 0 4.86ms 15
27° 81.9% 0.66V 264.2Hz 3156 0 4.86ms 16
27° 64.7% 0.68V 270.5Hz 3250 0 4.86ms 16
27° 67.1% 0.16V 276.8Hz 3281 0 4.86ms 17
27° 72.5% 0.70V 289.3Hz 3375 0 4.86ms 17
27° 58.5% 0.43V 301.9Hz 3469 0 5.12ms 18
27° 76.4% 0.64V 308.2Hz 3563 3 4.86ms 18
26° 71.8% 0.20V 327.1Hz 3656 3 6.40ms 25
26° 99.8% 0.82V 339.7Hz 3750 14 6.40ms 25
22° 99.8% 0.86V 364.8Hz 3844 13 7.17ms 29
21° 99.8% 0.88V 390.0Hz 3938 13 7.68ms 32
21° 99.8% 0.88V 415.1Hz 4031 13 7.94ms 34
20° 99.8% 0.88V 427.7Hz 4156 13 7.68ms 34
22° 99.8% 0.88V 415.1Hz 4250 12 7.42ms 33
23° 99.8% 0.88V 427.7Hz 4375 12 9.47ms 44
20° 99.8% 0.88V 647.9Hz 4563 12 13.57ms 66
14° 99.8% 0.88V 855.4Hz 4656 30 15.10ms 75
8° 99.8% 0.90V 849.2Hz 4781 9 14.85ms 75
13° 99.8% 0.90V 861.7Hz 4906 9 14.59ms 76
10° 99.8% 0.90V 880.6Hz 5125 16 14.08ms 77
15° 99.8% 0.90V 899.5Hz 5313 33 14.08ms 79
6° 99.8% 0.90V 918.3Hz 5500 43 14.08ms 82
7° 99.8% 0.90V 943.5Hz 5563 43 14.34ms 85
15° 99.8% 0.88V 968.7Hz 5656 9 14.08ms 85
10° 99.8% 0.90V 968.7Hz 5781 9 13.57ms 83
13° 99.8% 0.88V 962.4Hz 5875 9 13.82ms 86
18° 99.8% 0.88V 1031.6Hz 6063 29 13.31ms 86
12° 99.8% 0.88V 949.8Hz 6188 43 12.80ms 84
12° 99.8% 0.88V 1000.1Hz 6344 9 12.29ms 83
18° 99.8% 0.88V 912.1Hz 6531 8 12.03ms 83
17° 99.8% 0.88V 742.2Hz 6313 9 0.00ms 0
37° 99.8% 0.82V 144.7Hz 5781 0 1.54ms 9
45° 99.8% 0.74V 106.9Hz 5406 0 1.79ms 10
45° 99.8% 0.70V 88.1Hz 4969 0 1.54ms 8
45° 99.8% 0.70V 37.7Hz 4625 0 1.28ms 6
44° 99.8% 0.72V 18.9Hz 4281 0 1.28ms 5
You need to tell us more info, what are your safc settings, how does the car run during this, any smoke or other problems? It's obvious your knock sensor is going crazy, because 30 counts of knock is not safe. Who tuned your car? Don't drive under boost anymore until you figure this out. Also how much boost you running? Just need more info thats all.
Derek
Ahh, figures I didn't log tps. I will most def do that tomorow and report back with results. As far as tuning I have the afc zeroed out, because the stage 3 chip was doing great when I had my smic on. Also I'm running about 14lbs of boost when I logged this, and the 2x maf thing is correct as well, sorry I didn't mention that. I sincerely appreciate the repsonses. Tomorow evening their will be another log on this post. :talon:
I installed a new knock sensor two months ago when I rebuilt the engine. Do you think its worth a shot to install another one?... I probably have an old one laying around.
