NTRCOOL
- 0
- Apr 10, 2002
OVERHEATING? The issues and their solutions have remained the same- either you don't have enough cool air reaching the rad, there's a cooling system obstruction which is preventing coolant from circulating, or your head gasket has failed and is allowing coolant to be consumed or pushed away from the engine.
Discuss all possible overheating problems and solutions here.
OK,
I just left my house to go over to my GF's,and happen to look down and see my needle right before the red mark. This just happened out of nowhere. I stop the car as quickly as i can, and pour in some coolant(Coolant a little low). Still same thing. Welp im in the middle of the road, and HAD to get it home. Im only 5 min from my house. I decided to try and make it(I really had no other choice). Welp I drive no faster than 20mph, and the temp needle is BARELY into the red the whole way.And occasionaly to the left of it. Am I ok?? Do ya think any damage was done?? And im thinking either thermostat, or water pump. For each of those, whats a round about $$ figure to get replaced?? Any info you have would be GREATLY appreciated!
OK,
So since the dumbass i got it from drove the way he did with out barely having fluid in it i think its screwed...but all this started to happen after i put fluid in it....so inlighten me,im thinking getting a hg kit,a water pump, timing belt and the other belts, and also the decking stuff ive read about im not to knowledgeable with the internal engine stuff. should i take the head off and send it in to get it redone/? child support rapes my checks so im strapped....basically my symptoms go to it being a hg right? and i am on the right track?this is my third dsm, had a 95gs,and 90gs,but this damn thing is boggling my mind..SORRY ABOUT THREAD STEALING! and yes i read and read hours on end trying to come to a conclusion.thanks!
Thanks!
Switched it around, works fine.
