kchaazz
- 1,166
- 81
- Oct 2, 2002
PENSACOLA,
Florida
Hello there. Well, my car just doesnt feel as fast as she should be, you know?
First off, some info.
1. Just did compression test, yielding 150 psi across all 4, this was with 4 revolutions of the engine per cylinder.
2.Motor pulls 20 inches of vacuum at idle, which i believe is due to having a new head with less than 10,000 miles on it.
3. No smoke whatsoever
4. New plugs and wires, timing set correctly, and, of course, ngk bpr6es, (oem style 7mm wires though.)
5. Boost is set at 16psi.
6. On the logger, im getting from 18 to 25 degrees of timing advance and no knock anywhere at all at wot. My 02 voltage seems to change from .89v to .91v,every now and again to .93v. I know .91v is a tick rich, so .93v is for sure? (93 octane gas.)
7. Havent done a boost leak test for a week, but have never gotten above 6 psi though, (i know, thats horrible) however, the only place i could find a leak was the seals where the injectors go into the head, but i just got new seal from rre a few days ago.
Also, i put in new gaskets at the bov, the turbo outlet, the intake mannifold, and the throttlebody.(not tb shaft seals though)
8. Now, my car doesnt throw any codes for this, but it does miss randomly if i hold it at 1500 rpm or so in neutral, however, i cannot hear this random miss at 750 rpm idle.
Also, i cannot feel any stutter or bucking at wot or otherwise.
9.Also, my afpr is set at about 38- 39 psi with vac line off, safc 2 set at -30 across the board, only mod to mass is the lower hc is out, car idles great and runs just fine other than the power issue.
Conclusions, anyone?
and next month im getting a front mount ic- (20+ psi, here i come!!!)
