Templisk
- 214
- 0
- Jul 5, 2004
Brunswick,
Georgia
Alrighty, I went to disconnect my battery earlier to pull off the dash to paint it. Let the battery drain for a bit and got called home so I put everything together hooked up the battery and went to take off (hand-tightened the battery down)
The car started normally, let it idle for a minute and went to go and got about 5 feet and it died. I turned it back on and it died again. So I pushed it back to where it was, and tightened the battery down better with the tools. While I was doing this one of the bolts snapped (on the bottom right keeping the battery connected to the alternator)
So we went, bought another bolt and tightened it down again. When I started it up it was idling really really weird. Jumping from 1k to 200 rpm to 1.2k. I let it sit there for a while letting it warm up to see if that would work. It did, it stabilized at 900ish rpm and didn't move for 5 minutes so I went to drive off again. Again it died 5 feet from the house when I let off the gas completely. So I turned it on, and again it died.
So I turned it on again, and gave it gas after it fired up and as long as I held in the gas it stayed on. I didn't touch anything else at all, and have never had any problems lik ethis before. Please get back to me asap I don't have another ride home and I need to be home in about an hour.
Take my talon for example, it started off troubleshooting the driveline, next thing I know my entire enclosed porch is housing the entire interior and half the engine
All I have is a socket set and 6 screwdrivers
