Car idles but doesnt drive
motoman358
189
3
Jul 29, 2005
Oak Creek, Wisconsin
so, i picked up a 91 tsi automatic awd for a parts/money making oppertunity (i got an amazing deal), but the car doesnt drive. It will start, but as soon as you touch the throttle it dies out or stutters and recovers to an idle. I put in new plugs, set the timing, and checked for vac leaks (wasnt able to check for boost leaks yet as my tester is at my cousins). I know the tps is not adjusted proplerly, but i put it in many different positions and it didnt help at all. i noticed that it idled better with the maf unpluged, so i tried 2 others that i know worked and they still do the same thing. when they are pluged in the car runs worse han when unpluged. i pulled the ecu and noticed that the caps smell fishy, but i do not see any leakage yet nor do i see any visable cracks in them, could the ecu be the problem or are there other things i should check first?
ill try to get some pics tonight. but the board and caps look like brand new, no flaws, just a little smelly.
i cannot get pics of the ecu as my camera isnt working properly right now. is there anything else i should be checking until i can get pics posted? are my symptoms a sign of a bad ecu?
here is a pic of the ecu, i do see some leakage and damage to the board. where can i send it to get it repaired?
i cant get the picture to load for some reason?
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
