1G car idles fine but wont drive right
93 gsx skidz
43
Sep 15, 2012
masontown, Pennsylvania
my 93 gsx has a 6 bolt swap and it ran for 1 day then i bent vavles. now i just fixed the problem and it idles fine actually great but when i try to drive it starts to bulg out as i let the clutch out and give it gas. all 4 injectors spray at once while cranking its not a steady stream it just spurts out the whole time cranking is that normal and y does my car hold oil pressure until i try to drive. i cant figure this car out someone please help. no tap and no knock. got spark and fuel and oil is circulating what could it be.
I rechecked everything and I did the only vac leak I could do which is blow cigarette smoke thru a vac hose and smoke only came thru the throttle body and no where else. When I back up then pull forward the car bulgs out before I can fully let go of the clutch but if I ride the clutch I can move. The clutch is brand new and had no problens what soever before I bent valves and now I'm having problems. Could it be the mls gasket I put on ### I didn't have the head or the block resurfaced and that's the only thing I changed
Also I put the crank 1/4 tooth clockewise. I can't get it exact is that ok
