car idleing very lean
v8killer
371
5
Oct 4, 2002
harlan, Kentucky
well the car has the following that may help you figure out what causeing my lean idle condition. i have a AEM wb and it goes full lean ---- after startup. i have the 2g mas side screens out could that be causing it to go full lean ! i do have a very slight exhaust leak at the downpipe. parts ar in my profile. Thanks !
Do you have fuel control?? Is cruising still around 14.7 and WOT under 11.1?? I think a lot of stock dsm's run lean at idle, thats why we have to add a lot at idle to get a good afr. But since you are not under load at all, you should be fine. Wouldnt hurt to add fuel at that rpm and get a better afr if you have fuel control.
yes i have a moates ostrich and tunerpro rt so i can go up in that area i just didn't think it should be that lean, i may try and put the screensback in and see if that makes it richer .
A little exhaust leak before the WB o2 sensor is causing that situation. Exhaust gases, when flowing trough the exhaust pipe are creating a vaccuum wich is sucking fresh air into the exhaust pipe. Then, your o2 sensor is fooled by this fresh air.... and believe me, it wont take that much of a leak to completely fool o2 reading
Exactly right.
Good answer right there. I was thinking of that. It has to be his issue if he cant get a good afr at idle.
thanks guys i will try all you guys advice. starting with the mas screens "glad i kept them" then the exhaust leak.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
