Car Beeping, Won't Start!!!!
talon_ted
Feb 26, 2005
tupelo, Mississippi
1990 GS-T - Okay all, my car is totally back together, has a good ECU in it, but this is the problem. When I turn off the key, it just sits there making random beeping noises. Also, the oil light just sits there flickering. This is with the battery hooked up and the key out of the ignition. Upon trying to get the car to start, I only hear a "click" when the battery has PLENTY of charge. There had been a small engine fire, but I got all that stuff fixed I think, and the car HAS run since that fire occurred. Thanks for the help you guys, I'm in a DESPERATE situation here.
You're not getting power. Check and double check you battery connections, battery cables, grounds etc.
I know it sounds vague, but I'd bet that's your problem.
Good luck.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
