Cant read CEL code with MMCD v1.8G,why?
Galaxy
284
Aug 17, 2002
Gainesville, Florida
Searched pages of MMCD results.
Posted another similar question once as well with no response.
What could be wrong? Am I simply needing to use another version?
1.5 is even worse and won't log anything.
Any thoughts at all would really help,I just need to read the damn CEL so I can ignore it or fix whats wrong.
I read your other post and it seems you are having trouble finding the screen on the program to check CEL's. I am running a Palm III xe. When I first turn on the Palm I have my icon screen. I then select the MMCD icon. From here I get a page that has some past logs listed and it also has a button that says "new" at the bottom. At the very top left It says MMCD. Take your stylus and tap this and you'll get a drop down menu that says "Test" and "Debug." From the "Test" screen you can view stored and active codes as well as delete them and test solenoids, injectors, etc... I hope I understand your problem and that this will help you as it took me a couple of weeks to figure it out myself. Yeah I'm a little slow. Good luck
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
